Re: 460 motor swap
Posted by d282 on May 18, 2011 at 11:46:35 from (209.152.94.237):
In Reply to: 460 motor swap posted by hb5053 on May 18, 2011 at 10:51:53:
You will have to look close, but usually most of the following have to be changed in a combine to tractor swap:
timing cover, back plate, valve cover, oil pan, oil sump/pump, flywheel, manifold, oil filter base, oil cooler lines and I am sure something else, as there always seems to be something else with everything I do!
Good Luck
