Re: Farmall cub wont turn over
Posted by old on May 18, 2011 at 14:42:57 from (209.86.226.59):
In Reply to: Re: Farmall cub wont turn over posted by farmallboy15 on May 18, 2011 at 13:03:04:
Do you know 100% sure that the engine will turn over by hand??? If you do not try that first. If you can not turn it by hand pull the plugs and make sure you do not have fuel or water of something else hyd locking it. I'm guessing this is one of the older ones with the pull rod and switch on the starter. If you can turn it over by hand then double check every battery cable connection. Also you say you have tried 2 different starters do you use the same switch on both or do they have there own.
