Re: Farmall cub wont turn over
Posted by El Toro on May 18, 2011 at 17:24:36 from (108.15.86.54):
In Reply to: Re: Farmall cub wont turn over posted by farmallboy15 on May 18, 2011 at 13:03:04:
third party image
You should make sure the engine isn't stuck. Use your hand crank to turn over the engine. I would clean all the battery connections until they're shiny and tight and that includes where your battery is grounded. If the cables are cracked I would install 00 new cables. You should be able to start the engine using the hand crank. Make sure its not in gear. Hal
