Re: Farmall A quits running
Posted by Andy Dutkiewicz on May 19, 2011 at 07:12:14 from (69.174.58.28):
In Reply to: Re: Farmall A quits running posted by gene bender on May 19, 2011 at 07:09:33:
Thank you! I will check the coil and if that doesn't do the trick then I will most likely get a rebuilt magneto! Thank you again.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
