Re: Farmall A quits running
Posted by ddg on May 19, 2011 at 10:24:18 from (24.124.116.62):
In Reply to: Farmall A quits running posted by Andy Dutkiewicz on May 19, 2011 at 04:32:02:
My SA used to do the same thing 15 years ago when I switched from leaded to no-lead gass. And it got worse, down to about every ten minutes. I took the head off, and a few of the valves were so tight, they would stick in the guides when everything got warmed up. I started using a lead substitute or additive, and it ran fine. A couple of years later, it was due for an overhaul, and had the head rebuilt with modern valves & guides.
Today's Featured Article - Maintaining Rubber Tires - by Staff. The broad use of rubber tires on farm tractors and machinery has resulted in a great saving in both time and operating costs since the time of steel wheels. There are, however, certain basic fundamentals in the care of tires that should be followed carefully if the owner is to derive maximum benefit from his or her investment. First and most important is to maintain proper pressure for the work at hand. Your best guide to proper inflation is the operator's manual or instruction book tha ... [Read Article]
