well first off they only made 1250 lbs pressurre when they were new , and depending on what size cylinder is on a haybine it may not raise it . For a 450 to lift lets say a 469 you had best have a 3x8 on it . Most newer stuff uses smaller dia. cylinders because most of todays tractors ar up in the 2000 psi range or higher . Now as to your steering problem there are a couple things that would need be checked .
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
