Re: Cub Problem
Posted by XFARMA on May 19, 2011 at 18:03:44 from (66.82.162.14):
In Reply to: Cub Problem posted by _TD_ on May 19, 2011 at 11:23:52:
If your losing hyd oil and you don't see any external leaks then the hyd pump shaft seal maybe bad and allowing the hyd oil to leak into the crankcase raising the oil level in the oil pan high enough to come out the rear main seal and run out the insp plate hole.
