Re: Farmall 450 Diesel Hydraulic Problem? Just Bought
Posted by NEKS on May 19, 2011 at 20:55:59 from (71.0.217.103):
In Reply to: Farmall 450 Diesel Hydraulic Problem? Just Bought posted by toomuchonthebrain on May 19, 2011 at 11:54:30:
If the steering wheel turns hard like no powersteering hit one of the hydraulic levers and put turning pressure on the steering wheel the same time. If it turns them, you have the valve that directs oil to the powersteering pump sticking. Mines that way and I can live with it.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
