Re: push pull ignition switch to key conversion
Posted by D Slater on May 20, 2011 at 05:30:22 from (184.15.50.180):
In Reply to: Re: push pull ignition switch to key conversion posted by gene bender on May 20, 2011 at 05:00:27:
Like used in some construction equipment and can be found a lot of places by just searching the web. One that is made for over 1000 surge amps and over 100 continueous amps will be kind of costly. 1000-100 are probably okay for a C.
Works just like disconnecting a battery cable when off.
Just a idea I throwed out because the starting switch is on the starter operated by a pull rod and will turn the engine no matter what is done to the ignition switch.
