Posted by Dellbertt on May 20, 2011 at 15:20:20 from (209.172.21.168):
In Reply to: Cub Problem posted by _TD_ on May 19, 2011 at 11:23:52:
TD,
I picked up a Cub that had been used very little, mostly setting that had the exact problems as yours, decreasing hyd fluid, increasing crankcase oil. I figured as long as the o ring needs repacing I might as wll try stop leak first, I might get lucky.
I used LUCAS HD OIL STABILIZER in the crankcase and Lucas Hyd Stop Leak in the Hyd Fluid - it's ok to use Power Steering Stop Leak in the Hyd, I checked with Lucas, the PS is same formula as Hyd just concentrated more.
Two times mowing the lawn and the poblem stopped. That was two years ago and everything is still fine.
I normally agree with fix it right, but I gave this a shot and it worked. I think the o rings might have needed to be juiced up from lack of use.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
