Re: IH carb rebuilds
Posted by rhtx55 on May 20, 2011 at 16:21:27 from (207.119.50.41):
In Reply to: IH carb rebuilds posted by metalmender11 on May 20, 2011 at 15:08:27:
The float pivots on pins, check the side to side play, I 'll bet it's a bit loose causing the needle valve to sometimes stick, or you have some trash ( rust debris etc.) coming from the tank and getting between the needle & seat causing it to stick.
Make sure the sediment bowl is equipped with a screen at the top, and where the fuel line goes into the carb, there is a cone-shaped screen there also, these two together should keep most of the harmful stuff out of the needle & seat, if both are present and not dirty, it is probably the float pivot pin.
Some carb kits come with a rubber tipped needle valve, they are notorious for sticking, use a carb kit that contains an all metal needle valve & matching brass seat, they last much longer, won't stick, and are much more resistant to any rust or debris coming from the tank.
