Re: Thickness of Farmall A rims
Posted by Red Dave on May 20, 2011 at 17:22:22 from (98.235.13.108):
In Reply to: Thickness of Farmall A rims posted by Stevie J. Mote on May 20, 2011 at 17:16:36:
I don't know the exact measurements, but it is easy to see the difference between the cast wheel and the pressed steel.
The pressed steel is about 3/16th inch thick, maybe a little more, and a cast wheel is about an inch and a quarter.
Your cast wheel should be on the right side to balance the tractor.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
