If the person who repaired the pump ran it on a test bench it should prime up readily, but if he did not have a test bench it will take a whole lot of spinning that engine to get fuel through to injectors. I would take off the fittings at the injections nozzles and give it a good pull as this will save you a ton of cranking with the starter. Just be sure to have TA in direct drive (lever forward) and use high gear. I always remember the very first 560 we were trouble shooting back in about 1960 at service training, they had battery chargers hooked up and said, it will eventually start. What I got in the habit of doing when I repaired the pumps was hook them up to the tractor fuel supply with pump temporily mounted on side frame and put a hand operated speed wrench on them and cranked the heck out of them. Saved a lot of starter and battery. Also, I was able to be certain pump would deliver and shut off fuel. A runaway engine is always in the front of your thoughts when you have reassembled an injection pump. Never had it happen but came close once.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
