Re: IH carb rebuilds
Posted by SouthernFarmall on May 20, 2011 at 19:02:45 from (76.4.24.140):
In Reply to: IH carb rebuilds posted by metalmender11 on May 20, 2011 at 15:08:27:
If your float tang is bent, it can cause the needle to not be pushed up into the seat. If the tang is bent the other way, then the needle will be continually seated, and you will have no fuel. At least look at your float and make sure the tang is bent correctly. Also, if you replaced the needle and not the seat, there could be problems. Sometimes there are subtle differences between seats, and a brand new needle may not work right with an old seat.
Good luck, SF
