Fuel line coupling nuts sediment bowl to carb inlet
Posted by Greenie727 on May 20, 2011 at 19:30:42 from (24.61.144.125):
I have a slight fuel leak at the fuel line coupling nut at the sediment bowl outlet on my '45 Farmall A. What type of seal does this coupling nut use? Is there a compression ferrule on the end of the fuel line? My parts book lists coupling nuts P/N 29899D on each end of the fuel line. Are these nuts a slip fit over the fuel line and how do they seal to the fuel line and in the bowl and carb bodies? Do they require any dope on the external threads before installing? Thanks for any information.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
