Re: Farmall H starting problem
Posted by Allan In NE on May 21, 2011 at 06:54:19 from (148.66.88.254):
In Reply to: Farmall H starting problem posted by tseagan on May 21, 2011 at 06:41:35:
Starter is probably locked into the flywheel; fairly common problem. Loosen the mounting bolts and bump it. Then retighten.
Caused by a bad drive.
Allan
