Re: Farmall H starting problem
Posted by Greenie727 on May 21, 2011 at 07:05:42 from (24.61.144.125):
In Reply to: Farmall H starting problem posted by tseagan on May 21, 2011 at 06:41:35:
Check your battery terminal connections and all the heavy gauge wire connections at the starter switch and starter terminal stud. Your symptom looks and acts like the classic high resistance connection in that the starter engaged for 1/2 a second and then nothing. Clean and tighten all the connections and make sure the starter terminal does not turn while tightening. Any connection that gets real hot indicates a high resistance.
