Re: what's it take to convert fast hitch to 3 point?
Posted by K-Mo on May 21, 2011 at 08:45:31 from (67.55.164.37):
In Reply to: what's it take to convert fast hitch to 3 point? posted by realolman on May 21, 2011 at 04:23:57:
One thing I found to be a problem is the pivot point of the top link in relation to the pivot point of the hitch. I tried the 2-Pt prongs and anchored the top link directly behind the seat on my 240U. The pivot point for the hitch is far ahead of the top link point behind the seat. It was useless with a dirt scoop because it would radically change the pitch of the scoop while raising an lowering. I believe the adapter frame with the top link on the unit would work better. Some implements such as the dirt scoop may be more of a problem than others.
On a real 3-Pt, the top link and lower arm pivots are in a more vertical plain and the implement moves nearly straight up and down.
K-Mo
