Re: 1944 Farmall A starter question??
Posted by Larry Ed on May 21, 2011 at 14:29:46 from (67.142.175.27):
In Reply to: Re: 1944 Farmall A starter question?? posted by NDS on May 21, 2011 at 13:30:55:
Thanks, NDS, but I took the starter off and it all seems to be okay. I wanted to check the starter switch that is mounted on the starter for loose connections. Anyway, when the starter switch is off of the starter, and I touch the post on the starter with the positive cable from the battery, shouldn't it engage the starter? I'm getting good voltage to the starter, but the starter will not turn over.
