Posted by pete 23 on May 21, 2011 at 16:00:37 from (74.44.100.190):
In Reply to: Ih 550 plow posted by 4020deereboy on May 21, 2011 at 00:52:35:
It's all in the width of the tractor tread and the position the center pull point on the plow. No matter how bad or good the plow is working, running side ways or straight, the tractor should run straight with no side draft on tractor. Moving wheels and adjusting the hitch on a seven bottom plow is no five minute job I found out years ago when a customer was using his brakes to keep the tractor running straight. Tractor should run without even having a hand on the wheel theoretically. Plow is a whole different problem. Setting the tail wheel, correct land slide on rear bottom, gauge wheel, the steering linkage all involved.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You
... [Read Article]
Latest Ad:
[More Ads]
