Re: IH 444 Coil
Posted by Bob M on May 21, 2011 at 18:50:18 from (67.240.171.41):
In Reply to: IH 444 Coil posted by Paul J. on May 21, 2011 at 17:14:03:
Paul - A good 12 volt coil primary will show between about 3 and 5 ohms; a 6 volt coil's primary resistance will be half that.
Secondary resistance for both 6 and 12 volt coils is generally between about 2.5K and 4K ohms. (Individual coil resistances may vary outside this range...)
Now if you read either a dead short (0 ohms) or an open (infinite resistance) in either coil winding you know the coil is bad. HOWEVER a coil can still be bad even when both windings' resistance values are within tolerance.
