Re: farmall 12 volt conversion
Posted by Jon Hagen on May 21, 2011 at 18:57:59 from (69.26.23.96):
In Reply to: farmall 12 volt conversion posted by John Lundberg on May 21, 2011 at 17:46:20:
The link below will help you with the wiring.
One part of your post has me a little confused. you state that you bought a 12V coil .
If you have a true 12V coil with a 3 ohm primary winding, then you do not need the ceramic block ballast resistor.
If your new coil is marked "12V with external ballast resistor", it has a 1.5 ohm primary winding, then you do need the ceramic ballast resistor. You need to determine which coil type you have before installing a ballast resistor, or not.
