Re: Farmall A Oil Pump
Posted by Owen Aaland on May 21, 2011 at 22:28:08 from (216.47.32.42):
In Reply to: Farmall A Oil Pump posted by Archie McArdle on May 21, 2011 at 11:43:57:
Take the bottom of the pump off to make sure the pump is not seized. The pump shaft needs to rotate as it is removed from the camshaft. If the pump shaft can not turn you will break something by forcing the pump down.
