Re: 660 belt pulley gearbox
Posted by D Slater on May 22, 2011 at 09:36:49 from (184.15.50.180):
In Reply to: 660 belt pulley gearbox posted by Farmboy856 on May 22, 2011 at 05:30:39:
If the housing will clear everything on the tractor they will bolt up. Probably have to modify the shifter shaft lever and linkage to use unless the parts from a international 560 will work. Some belt pulley housings are made for more clearance to remove and install starters.
Keep in mind that shaft speed will be more than a M. Probably why IH wanted a rear unit used.
