Re: Farmall A Oil Pump
Posted by CharlieNJ on May 22, 2011 at 09:47:32 from (76.117.68.151):
In Reply to: Re: Farmall A Oil Pump posted by Archie McArdle on May 21, 2011 at 21:26:35:
If you take the crank out the cam should turn. The oil pump gear is a bevel gear.
Regards,
Charlie
