Re: Kohler 1650 Engine (K341)
Posted by kennell on May 22, 2011 at 10:01:42 from (142.68.110.178):
In Reply to: Kohler 1650 Engine (K341) posted by Pierre G. Joly on May 22, 2011 at 07:18:17:
The engine is mounted in rubber, so make sure you have a good ground running from the starter to the frameof the tractor. This is the most likely starting problem with the "shaker" models. Normally the compression release doesn't give much problem. Kent
