Posted by Wardner on May 22, 2011 at 12:03:47 from (209.86.226.27):
In Reply to: Super C Fast Hitch posted by BillB52 on May 22, 2011 at 06:07:05:
The balls on the 400 use a roll pin inside of a larger roll pin. I have had no problem driving both out at the same time. The ball should slide off without too much persuasion.
You might want to mark them so that if there is wear (yep, you have some), you can reassemble them either upside down or rotated 180 to take up some slop. Best solution would be to get a new socket arm.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
