Re: Help with Farmall H after electronic ignition install
Posted by Stevishere on May 22, 2011 at 12:45:23 from (24.56.222.202):
In Reply to: Help with Farmall H after electronic ignition install posted by WaltZ on May 08, 2011 at 17:00:25:
I think you are correct. I loosened the distributor, then started moving it CCW a couple of degrees, try to start, repeat.
After moving it about 10 degrees CCW, it started up. I continued moving it until it ran smooth, probably about 20 degrees CCW.
I read that my timing mark is on the crankshaft fan pulley. KNow I need to know how to go about setting the timing correctly.
Anybody out there have specifics?
Thanks! 8)
