Don't think a snowblower on a C has much merit for the reasons others have mentioned. However, a 20" impeller fan will need a minimum of 540 rpm and will do alot better at 650 rpm.
Secondly, you won't be able to run a full width blower, not enough power. Think about an offset so that one rear tire runs on cleared ground. Set up your sprockets at the rear so that the shaft forward goes under the axle.
Use a telescoping shaft (or at least a slip yoke), U-joints, and three bearings. Pictures are of a W400.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
