Polarity does not matter as long as you have + to + and - to -. Your problem is likely not the battery or starter if both are new, but the connections. Could be a cable problem. This past Friday I replaced what appeared to be a perfecly good ground cable on my M, was cranking very slowly. Started right up, there was corrosion under the insulation. It is seldom a battery or starter problem.
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
