The best way to do the adjustment is to use a flat surface and a spacer as thick as the lever height measurement. Use a heavy washer to catch all three levers and a bolt through your surface plate or a small plate and a press to hold the levers at the spacer height. Then adjust the levers until you get the right measurement between the surface plate and the underside of of the clutch cover where the mounting bolts are located.
An alternate method is to use the correct height spacers under the clutch cover at the mounting holes and pull the cover down until they are tight. Then adjust the levers until you get the correct lever height.
The first method is best because that has the adjustments made with spring pressure against the levers to take up any movement between holes and pivot pins. With the second method there is no tension on the levers and any adjustment may be off due to worn parts.
Usually you are better off not trying to make any adjustment on the clutch levers because it is very difficult to get the adjustments set as close as a rebuild PPA is set to.
If you really have to make adjustments without the proper setting tools you can get pretty close by having the flywheel off and setting it on a level surface. Once the flywheel is level install the disk and PPA. Adjust the levers until they are horizontal. Use a heavy washer or small plate that will cover all three levers. Put a level on the plate and do final adjustments until the plate is level.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
