more cub problems!
Posted by farmallboy15 on May 23, 2011 at 16:27:23 from (12.213.80.36):
this is a different cub from last week. ive been using it to plant all weekend. and on my back to the barn it started sputtering and i pushed the clutch in and it came back a little then it started sputtering and completly died and refused to start. came back a few hours later and after playing with the choke and throttle i got it to start up and act just fine. put it in the barn and now it wont start at all. it will sputter a little but not run. i read some past posts and switched the coil with another tractor. there was some sediment in the bowl. i have good flow to the carb. but when i opened the drain a bunch of gas came out. when i turned the fuel line on just a trickle came out the drain. what do you guys think? something clogged up in the carb / float problems? thanks in advance!
