Re: International 1486 PTO shaft
Posted by Redfan on August 01, 2000 at 19:20:43 from (203.87.53.9):
In Reply to: International 1486 PTO shaft posted by Ron on August 01, 2000 at 10:22:40:
Yes, lower post is correct. You need to have someone work the gear over the splines as you are rolling the two halves back together. Correct way is to install gear locaters, which hold gear in place as tractor is split, and this simplifies installation. I've done it the "incorrect" way a number of times and it's relatively simple. Be careful the tractor doesn't fall,that can be messy.Regards, Redfan.
Post A Followup
: Re: Re: International 1486 PTO shaft
