Re: A push rods
Posted by Nebraska Cowman on May 23, 2011 at 19:48:11 from (66.252.115.12):
In Reply to: A push rods posted by truckinthumbtack on May 23, 2011 at 19:42:08:
Or good used. If they are pitted that bad I'd pitch them. Grinding away material ain't gonna fix them.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
