Get into the mowable grass and start mowing. While going straight, shut off the engine and let it stop. Take the PTO out of gear, then carefully look at the grass being cut. Starting in front of the tractor, and continuing under the deck till you get to the blades. This should indicate what is happening as it cuts. Smashed down grass can respond to a second reverse direction cut. Short blades are a real possibility. Be careful to check all clearances if longer blades are used. Do not compromise with the wrong blades. Use OEM or replacement blades made for it. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
