Re: Farmall A stalling at high RPMs.
Posted by CharlieNJ on May 24, 2011 at 18:31:44 from (76.117.68.151):
In Reply to: Re: Farmall A stalling at high RPMs. posted by Mr Farmall on May 23, 2011 at 21:36:59:
Mr. Farmall, you could spray around the intake, you could try an un-lit propane torch, you could visually inspect the gaskets. You might try the nuts to see if they are tight to torque. The studs use hardened washers under the nuts on all but the outside studs. If you change the gaskets, make sure the manifold is straight with a straight edge.
Regards,
Charlie
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
