Re: VR Wiring help please
Posted by teddy52food on May 24, 2011 at 18:54:30 from (68.169.216.43):
In Reply to: VR Wiring help please posted by WY JERRY on May 24, 2011 at 17:56:48:
I am just guessing, so don't connect it up until some one conferms it. #4 goes to A on the gen. If that coil by #3 has the points open, it would be the cut-out so #3 gets battery voltage.#1 should be the field connected to field on the gen. The points should be closed on that coil. #2 would be load which you can leave open, or run a wire to feed the lights. I am unsure about #1&2, but if you put battery to #3 , it should show voltage on #2 also. If not check #1. Look real close to those connections next to the screws. There should be A&F&BAT&L. Wait for John T to respond.
