Posted by rustyfarmall on May 25, 2011 at 06:57:01 from (216.248.71.224):
In Reply to: H distributor posted by David G on May 25, 2011 at 06:54:37:
Look closely and you will see a small pipe plug. Remove that plug and install a grease zerk. Your owners manual has instructions on how often to grease that zerk. BUT!! If you have oil under the distributor cap, you need to replace some oil seals in that hydraulic pump. Probably at each end.
Today's Featured Article - Field Modifications (Sins of the Farmer) - by Staff. Picture a new Chevrolet driving down the street without it's grill, right fender and trunk lid. Imagine a crude hole made in the hood to accommodate a new taller air cleaner, the fender wells cut away to make way for larger tires, and half of a sliding glass door used to replace the windshield. Top that off with an old set of '36 Ford headlight shells bolted to the hood. Pretty unlikely for a car... but for a tractor, this is pretty normal. It seems that more often than not they a
... [Read Article]
Latest Ad:
[More Ads]
