Re: farmall super m
Posted by SouthernFarmall on May 25, 2011 at 19:23:32 from (76.4.24.140):
In Reply to: farmall super m posted by Charlie reed on May 25, 2011 at 19:14:04:
I believe what you are describing is called a hydro-lock. I don't have much experience working on this problem, but if you Google "hydro-locked engine" I am sure you can get some good results.
SF
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
