Re: farmall super m
Posted by Janicholson on May 25, 2011 at 19:43:29 from (67.72.98.45):
In Reply to: farmall super m posted by Charlie reed on May 25, 2011 at 19:14:04:
I agree it is probably the starter locked up loosen it and it should free up the engine. Re-tighten the starter and it will be OK. Change the oil. It will be 3/4 gasoline!.
Always (always) turn off the fuel at the tank.
Even if stopped for 15 minutes, it is a necessary reality and polishes up the brass on the little valve. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
