Re: farmall super m
Posted by SouthernFarmall on May 25, 2011 at 20:23:31 from (76.4.24.140):
In Reply to: Re: farmall super m posted by pete 23 on May 25, 2011 at 19:33:22:
Yes, I agree that the problem could very well be the starter locked up on the bendix. Sometimes you can tap the starter with a ball peen hammer and free it up. If that doesn't work, I have heard that you can try rocking the tractor back and forth in high gear. I wouldn't take the starter off until you try these methods.
SF
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
