Posted by robgIN on May 26, 2011 at 04:42:09 from (76.208.4.134):
In Reply to: farmall super m posted by Charlie reed on May 25, 2011 at 19:14:04:
I'm with the locked starter group, happens a lot. Loosen it up and wiggle it, it will pop free. Updraft carb, well below cylinders not likely to hydro lock, gas usually runs out drain hole in carb.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
