Re: farmall super m
Posted by rustyfarmall on May 26, 2011 at 10:47:21 from (216.248.71.224):
In Reply to: farmall super m posted by mkirsch on May 26, 2011 at 08:18:26:
Or spun a bearing because the gasoline in the crankcase washed all the oil out.
The gas tank on that tractor would have to had been completely full before gasoline leaking by the float valve in the carburetor could get high enough to pass through the manifold and into the cylinders. The gasoline would have filled the oil pan and crankcase first. You need to drop the oil pan and take a peek up inside the engine. My guess is that the engine is seized from lack of lubrication.
