farmall M voltage reg
Posted by Finnbair2020 on May 26, 2011 at 13:53:35 from (71.161.125.102):
I'm working on my Farmall M, trying to get it to charge. If, after it is started, you press down on the points in the voltage regulator, they will stay down and the tractor will charge. If you do not press down on them, they do not go down and the tractor dos not charge. Is there a way to fix this, besides purchasing a new voltage regulator?
Second question-- has anyone seen a heat plug installed on the top of the block on a tractor like this? Haven't seen one in this location before but can't imagine what else it might be--
