Re: '49 H Inline fuel filter
Posted by SouthernFarmall on May 26, 2011 at 18:29:05 from (76.4.24.140):
In Reply to: '49 H Inline fuel filter posted by FarmallJon on May 26, 2011 at 18:12:11:
Many people will try tell you otherwise, but I know from experience that in-line fuel filters work fine with gravity feed systems. I got my 140 with an in-line fuel filter, and have kept it that way. The only downside is that the filters must be changed often. If your tank is really dirty, it may be more trouble than it is worth to install one. You may be better off cleaning the tank again. But, if there truly is only a little bit of crud in there, an in-line filter will work fine. In fact, if I were you, I probably would install one myself!
SF
PS: There is a strainer in the carb that will become clogged with crud eventually, so it will be better to have the junk caught where you can easily access it (the in-line filter) than in the carb.
