A gravity feed fuel system operates at low pressure. Moderate restriction caused by a fuel filter can reduce the fuel pressure to a dangerous level and cause a lean the air/fuel mixture. The air/fuel mixture needed for combustion may not be enough to keep the combustion chambers cool while operating under load. If an engine is running so lean that the piston and chamber have heated up more than tolerances will allow, the piston may grind against the cylinder wall until it freezes. Excessive heat can burn a valve or melt a hole in the piston.
It would be interesting to find out if melted pistons are a common failure in IH engines?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
