I did a Farmall A back in 1975-1976. After removing the hood,grille and radiator I unbolted the front steering and rolled the front wheels along with the steering wheel out from under the tractor after supporting the engine. You need a block under the drawbar since once you pull the engine the tractor will tilt backwards. Those engines have dowels and you need to wiggle the engine and once you get a little gap between the engine and dowel use a flat blade screwdriver to pry the engine off the dowels. Use a suitable hoist to handle that engine. The clutch assy should be on the engine too. Good time to have that rebuilt when its off the engine. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
