Re: Pulling the motor out of Super A today. Any tips?
Posted by P and R Pete on May 27, 2011 at 06:31:07 from (173.86.1.230):
In Reply to: Pulling the motor out of Super A today. Any tips? posted by GRAPE-DRANK on May 26, 2011 at 23:02:30:
I rebuilt my engine two years ago. I took a lot of pictures, if any will be helpful. Where are you in the process? I blocked under the front end of the torque tube, and never had any issue with the tractor trying to tip over backward, even after I took the heavy hydraulic block off the torque tube. You can see it here...
third party image
third party image
The entire front end, with the steering wheel, can be unbolted off and walked away (you can even still steer!) from the front of the tractor. Then I stripped everything else off the block, and used a cherry=picker on the block. Didn't take much wiggling to get it loose, and then I put it on an engine stand.
Not knowing where you are, *ping* again if you have another question.
