Re: INT.#8 2 Bottom trop plow
Posted by AG in IN on May 27, 2011 at 11:46:40 from (67.236.70.34):
In Reply to: INT.#8 2 Bottom trop plow posted by CNKS on May 27, 2011 at 11:14:57:
Put set collars on the rod that goes through the rear axle bracket arm, one on each side, to lock the rear wheel in place. Or, cheat and use vise grips.
AG
