Re: farmall 656 gas electrical problem
Posted by Janicholson on May 27, 2011 at 17:02:26 from (67.72.98.45):
In Reply to: farmall 656 gas electrical problem posted by alih656 on May 27, 2011 at 14:40:23:
Probable stuck cutout points in the Regulator if it is a generator. Or a bad diode if it is an alternator. If it is an alternator, do not use the analysis described below.
Alternators are aluminum with spade connectors and one stud for the battery connection.
Generators have two side mounted studs and are iron. Jim
